Jamf Pro Health Check Page
The Jamf Pro health check page allows you to view the status of your environment. This can be useful for identifying performance and configuration issues. For example, you can use the Jamf Pro health check page to ensure all instances of the Jamf Pro web app in a clustered environment are running without error.
Note: The Jamf Pro health check page is not the same as the Jamf Pro Health Check service offered by Jamf Professional Services.
The following table lists the possible status the Jamf Pro health check page may return:
Status
Description
[{"healthCode":1,"httpCode":503,"description":"DBConnectionError"}]
An error occurred while testing the database connection.
[{"healthCode":2,"httpCode"200:,"description":"SetupAssistant"}]
The Jamf Pro Setup Assistant was detected.
[{"healthCode":3,"httpCode":503,"description":"DBConnectionConfigError"}]
A configuration error occurred while attempting to connect to the database.
[{"healthCode":4,"httpCode":503,"description":"Initializing"}]
The Jamf Pro web app is initializing.
[{"healthCode":5,"httpCode":503,"description":"ChildNodeStartUpError"}]
An instance of the Jamf Pro web app in a clustered environment failed to start.
[{"healthCode":6,"httpCode":503,"description":"InitializationError"}]
A fatal error occurred and prevented the Jamf Pro web app from starting.
The Jamf Pro web app is running without error.
Using the Jamf Pro Health Check Page
To navigate to the Jamf Pro health check page, append "healthCheck.html" to your Jamf Pro URL. For example:
  • https://instancename.jamfcloud.com/healthCheck.html (hosted in Jamf Cloud)
  • https://jss.instancename.com:8443/healthCheck.html (hosted on-premise)
The status of your environment displays on the screen.
Once you have identified the status of your environment, you can take steps to resolve any issues that were found.
