Advanced Volume Purchasing Content Searches for Mobile Devices
Advanced volume purchasing content searches allow you to use detailed search criteria to search mobile device apps and books in Jamf Pro. These types of searches give you more control over your search by allowing you to do the following:
Generate specific search results.
Specify which attribute fields to display in the search results.
Save the search.
Creating an Advanced Volume Purchasing Content Search
Log in to Jamf Pro.
Click Devices at the top of the page.
Click Search Volume Content.
Click New
Use the Search pane to configure basic settings for the search.
To save the search, select the Save this Search checkbox. -
Click the Criteria tab and add criteria for the search:
Click Add
Click Choose for the criteria you want to add.
Choose an operator from the Operator pop-up menu.
Enter a value in the Value field or browse for a value by clicking Browse
Repeat steps a through d to add criteria as needed.
Choose an operator from the And/Or pop-up menus to specify the relationships between criteria.
To group criteria and join multiple operations, choose parentheses from the pop-up menus around the criteria you want to group.
Click the Display tab and select the attribute fields you want to display in your search results.
Click Save.
The results of a saved search are updated each time content is modified and meets or fails to meet the specified search criteria.
To view the search results, click View.
Viewing Advanced Volume Purchasing Content Search Results
Log in to Jamf Pro.
Click the advanced volume purchasing content search you want to view the results for.
Click View.
Related Information
Simple Volume Purchasing Content Searches for Mobile Devices
Learn how to quickly search volume purchasing content for a general range of results. -
Volume Purchasing Content Reports for Mobile Devices
Find out how to export the data in your search results to different file formats.
