Viewing and Editing Inventory Information for a Mobile Device
Jamf Pro stores detailed inventory information for each managed mobile device. You can view and edit this information from Jamf Pro. For more information about the inventory information you can collect, see Mobile Device Inventory Collection Settings.
Note: The inventory information displayed for a particular device varies depending on the device ownership type, device type, and OS version. For more information, see Mobile Device Management Capabilities.
If a device is enrolled with Jamf Pro via a PreStage enrollment, you can use the PreStage Enrollment settings to specify the information that is submitted by the device and stored in Jamf Pro. For more information, see Mobile Device PreStage Enrollments.
Re-enrolling a device with Jamf Pro retains the inventory information that was collected for the device prior to re-enrollment. This information, however, can be cleared or changed depending on the Re-enrollment settings. For more information, see Re-enrollment Settings. In addition, if the device is re-enrolled via a PreStage enrollment, there are settings that can affect the user and location information for that device. For more information, see Mobile Device PreStage Enrollments.
The following table lists all possible information that you can view and edit for each mobile device.
Note: Extension attributes are displayed in mobile device inventory information in the category in which they are configured to display.
Field
Editable
Notes
Personally Owned iOS Device Support
General Category
Mobile Device Name
images/download/thumbnails/79168236/checkmark.png
Editable for supervised devices with iOS 8 or later when Enforce Mobile Device Name is configured
When Enforce Mobile Device Name is configured, Jamf Pro enforces the name in one of two ways:
  • If the enforced device name differs from the device name in the most recent inventory record for the device, Jamf Pro sends an MDM command that renames the device.
  • If the end user changes the device name to something different than what Jamf Pro is set to enforce, the next time the device submits its inventory, Jamf Pro sends an MDM command to rename the device.
Jamf Pro Mobile Device ID
Asset Tag
Site
Last Inventory Update
iOS Version
For Apple TV devices prior to tvOS 10.2, the iOS version is equivalent to the OS build version on which the Apple TV software is based. The Apple TV software version is not collected.
For Apple TV devices with tvOS 10.2 or later, the tvOS version is displayed.
iOS Build
IP Address
Managed
Supervised
Shared iPad
Displays whether Shared iPad has been enabled on the iPad. (This only displays for supervised iPads with iOS 9.3 or later.)
Maximum Shared iPad Users Stored
Displays the maximum number of user accounts that can be stored with Shared iPad
Device Ownership Type
Enrollment Method
Last Enrollment
Device Locator Service Enabled
Displays whether Find my iPhone/iPad has been enabled on the mobile device
Do Not Disturb Enabled
iCloud Backup
Last iCloud Backup
Bluetooth Low Energy Capability
To detect Bluetooth Low Energy capability, the mobile device must have Jamf Self Service for iOS installed. If Self Service has never been launched on the device, this value will be reported as “Not Capable/Unknown”.
Location Services For Jamf Self Service
Displays whether Location Services has been enabled on the mobile device for the Jamf Self Service app
To detect if Location Services has been enabled for Self Service, the device must have Jamf Self Service for iOS installed. If Self Service has never been launched on the device, or if Self Service has not been launched since the initial iBeacon region was added to Jamf Pro, this value will be reported as “Not Enabled/Unknown”.
Logged in to iTunes Store
AirPlay Password
Apple TV only
Locales
Apple TV only
Languages
Apple TV only
Hardware Category
Capacity
Available Space
Used Space
Internal Capacity
Internal Available Space
Internal Used Space
External Capacity
External Available Space
External Used Space
Battery Level
Serial Number
images/download/thumbnails/79168236/checkmark0.png 1
UDID
Wi-Fi MAC Address
Bluetooth MAC Address
Modem Firmware Version
Model
Model Identifier
Model Number
Manufacturer
User and Location Category
Username
You can assign a user to the mobile device and populate user information from the Users tab. For more information, see User Assignments.
Note: To assign a user to a device, the Jamf Pro user account must have the "Assign Users to Mobile Devices" privilege.
Full Name
Email Address
Phone Number
Position
Department
Building
Room
Shared iPad Users Category
images/download/thumbnails/12323547/checkmark.png
You can remove users from Shared iPad. The status of user removal is displayed in the list of pending management commands. For more information, see Viewing the Pending Management Commands for a Mobile Device.
Displays a list of the Managed Apple IDs of the users that logged in to the iPad. This category is only displayed for iPads that have Shared iPad enabled. For more information, see Mobile Device PreStage Enrollments.
Purchasing Category
Purchased or Leased
You can look up and populate purchasing information from Apple’s Global Service Exchange (GSX). (This requires a GSX connection set up in Jamf Pro. For more information, see Integrating with GSX.)
PO Number
PO Date
Vendor
Warranty Expiration
AppleCare ID
Lease Expiration
Purchase Price
Life Expectancy
Purchasing Account
Purchasing Contact
Extension Attributes Category
Displays a list of custom data fields collected using extension attributes
Security Category
Data Protection
Hardware Encryption
Passcode Status
Block Encryption Capability
File Encryption Capability
Passcode Compliance
Passcode Compliance with Config Profile
Activation Lock
Jailbreak Detected
To detect jailbreak status, the mobile device must have Jamf Self Service for iOS installed. Jamf Pro will receive an updated Jailbreak Detected value each time Self Service is launched. If Self Service has never been launched on the device, this value will be reported as “Not Reported”.
Lost Mode (supervised only)
Displays whether Lost Mode is enabled on the device
You can play a sound on the device when Lost Mode is enabled by clicking the Play Sound button.
Always enforce Lost Mode
Displays whether the Always enforce Lost Mode setting is enabled on the device.
Lost Mode Message
Lost Mode Phone Number
Lost Mode Footnote
Last Location Update
Displays the last time Global Positioning System (GPS) data was collected for the device when Lost Mode is enabled
Approximate Location
You can collect updated location data for the device by clicking the Update Location button.
Displays coordinates for the approximate location of the device when Lost Mode is enabled
To collect GPS data for a device, the device must have a network connection.
Horizontal Accuracy
Vertical Accuracy
Altitude
Speed
Course
Timestamp
Personal Device Profile Status
Displays whether the most up-to-date profile has been installed on the mobile device
Apps Category
Displays a list of apps installed on the mobile device
Note: Only managed apps are collected.
Managed eBooks Category
Displays a list of managed books installed on the mobile device
Network Category
Home Carrier Network
Current Carrier Network
Carrier Settings Version
Cellular Technology
Phone Number
IMEI
MEID
ICCID
Current Mobile Country Code
Current Mobile Network Code
Home Mobile Country Code
Home Mobile Network Code
Voice Roaming
Data Roaming Status
Roaming Status
Personal Hotspot Status
iBeacon Regions Category
Displays a list of iBeacon regions that the mobile device is currently in. (This category is only displayed if the Mobile Device Inventory Collection settings are configured to monitor iBeacon regions. For more information, see Mobile Device Inventory Collection Settings.)
Certificates Category
Displays a list of certificates installed on the mobile device
Profiles Category
Displays a list of profiles installed on the mobile device
Provisioning Profiles Category
Displays a list of provisioning profiles installed on the mobile device
Attachments Category
You can upload and delete attachments.
Displays a list of files attached to the inventory record
Notes:
1. Devices enrolled using User Enrollment do not report any persistent device identities.
Viewing Inventory Information for a Mobile Device
  1. Log in to Jamf Pro.
  3. Perform a simple or advanced mobile device search.
    For more information, see Simple Mobile Device Searches or Advanced Mobile Device Searches .
  4. Click the mobile device you want to view information for.
    If you performed a simple search for an item other than mobile devices, you must click Expand images/download/thumbnails/79168236/Icon_Expand.png next to an item to view the devices related to that item.
    The mobile device’s inventory information is displayed.
  5. Use the categories to view information for the mobile device.
  4. Click the mobile device you want to edit information for.
  5. Select the category that contains the information you want to edit and click Edit.
  6. Make changes as needed.
    If you are editing user and location information, the changes are applied in the Users tab. This specified information is also applied in the inventory information for computers and other mobile devices that the user is assigned to. For information on assigning a user to a mobile device or removing a user assignment, see User Assignments.
  7. (Optional) To rename a supervised device, click the Enforce Mobile Device Name checkbox, and then enter the new device name in the Mobile Device Name field.
  8. (Optional) To populate device purchasing information from Apple’s Global Service Exchange (GSX), click Search images/download/thumbnails/17106156/Icon_Search.png .
  9. Click Save.
