LDAP Proxy
Jamf Pro allows you to enable an LDAP Proxy. Enabling an LDAP Proxy creates a secure tunnel to allow traffic to pass between Jamf Pro and an LDAP directory service. For example, if your environment uses a firewall, an LDAP Proxy can be used to allow a directory service on an internal network to pass information securely between the directory service and Jamf Pro.
The LDAP Proxy is hosted by the Infrastructure Manager, a service that is managed by Jamf Pro. After you install an instance of the Infrastructure Manager, Jamf Pro allows you to enable an LDAP Proxy if you have an LDAP server set up in Jamf Pro. For more information, see Jamf Infrastructure Manager Instances.
Note: The LDAP Proxy that is hosted on the Infrastructure Manager is not the same service as the open source NetBoot/SUS/LP server. For more information about the open source NetBoot/SUS/LP server, see the following webpage: https://github.com/jamf/NetSUS/tree/master/docs .
Network Communication
When using the LDAP Proxy, the Jamf Infrastructure Manager can be customized for incoming access by any available port 1024 or greater. The port used must be opened, inbound, on your firewall and also on the computer on which the Infrastructure Manager is installed. The recommended port is 8389 for communication between your Jamf Pro server and the Infrastructure Manager.
Note: The Infrastructure Manager cannot be installed behind a proxy server in your environment.
For communication between the Infrastructure Manager and an LDAP directory service, your LDAP server’s regular incoming port is used. This port is specified in the LDAP server’s configuration in Jamf Pro. The most common configurations are port 389 for LDAP and port 636 for LDAPS. This communication occurs between the Infrastructure Manager in the DMZ and an internal LDAP directory service only.
Note: The Infrastructure Manager does not support Network Address Translation (NAT).
When using Jamf Pro hosted on Jamf Cloud, the necessary external IP addresses for Jamf Cloud must be allowed inbound to the Infrastructure Manager. For more information, see the Permitting Inbound/Outbound Traffic with Jamf Cloud Knowledge Base article.
Note: Internal domain addresses (for example, .local, .company, or .mybiz) are not supported at this time. The Infrastructure Manager must be resolvable to the external Jamf Pro server.
For more information about network communication and the connections initiated between the Infrastructure Manager and Jamf Pro, see the Network Ports Used by Jamf Pro Knowledge Base article.
Requirements
To configure an LDAP Proxy, you need the following:
Configuring the LDAP Proxy
  1. Log in to Jamf Pro.
  2. In the top-right corner of the page, click Settings images/download/thumbnails/34734608/Icon_Settings_Hover.png .
  3. Click System Settings.
  4. Click LDAP Servers images/download/thumbnails/12988462/LDAP_Servers.png .
  5. Click the LDAP Server to which you want to assign an LDAP Proxy.
  6. Click Edit.
  7. Select the Enable LDAP Proxy checkbox.
  8. Select the proxy server to use.
    The proxy binding address is automatically populated based on the server you select.
  9. Enter a port number.
  10. Click Save.
