Viewing and Editing Inventory Information for a Computer
The Jamf Software Server (JSS) stores detailed inventory information for each computer. You can view and edit this information from the JSS.
The following table lists the information that you can view and edit for each computer.
Note: Extension attributes are displayed in computer inventory information in the category in which they are configured to display.
Field
Editable
Notes
General Category
Computer Name
images/download/thumbnails/15182254/checkmark.png
Site
Last Inventory Update
Last Check-in
IP Address
Reported IP Address
jamf binary Version
Platform
Managed
Enrollment Method
Last Enrollment
MDM Capability
JSS Computer ID
Asset Tag
Bar Code 1
Bar Code 2
Bluetooth Low Energy Capability
Logged in to iTunes Store
This value will be reported as “Active” when a user-level configuration profile is installed from Self Service using MDM-enabled credentials
Management Account Username
Management Account Password
Hardware Category
Make
Model
Model Identifier
UDID
Serial Number
Processor Speed
Number of Processors
Number of Cores
Processor Type
Architecture Type
Bus Speed
Cache Size
Primary MAC Address
Secondary MAC Address
Total RAM
Available RAM Slots
Battery Capacity
SMC Version
NIC Speed
Optical Drive
Boot ROM
Operating System Category
Operating System
Operating System Version
Operating System Build
Active Directory Status
Master Password Set
FileVault Users
Service Pack
User and Location Category
Username
You can assign a user to the computer and populate user information from the Users tab. (For more information, see User Assignments .)
Full Name
Email Address
Phone Number
Position
Department
Building
Room
Security Category
System Integrity Protection
Displays whether System Integrity Protection is enabled for a computer (collected for macOS 10.11 or later only).
For more information, see the Working with Apple's Gatekeeper and System Integrity Protection Features in Jamf Pro Knowledge Base article.
Gatekeeper
Displays whether Gatekeeper is enabled for a computer (collected for macOS 10.9 or later only).
Purchasing Category
Purchased or Leased
You can look up and populate purchasing information from Apple’s Global
Service Exchange (GSX).
(This requires a GSX connection set up in the JSS. For more information, see Integrating with GSX.)
PO Number
PO Date
Vendor
Warranty Expiration
AppleCare ID
Lease Expiration
Purchase Price
Life Expectancy
Purchasing Account
Purchasing Contact
Extension Attributes Category
Non-script extension attributes only
Displays a list of custom data fields collected using extension attributes.
Storage Category
Model
Revision
Serial Number
Drive Capacity
S.M.A.R.T. Status
Number of Partitions
Name
Displays the name of the partition
Size
Displays the size of the partition
% Used
Displays the % used of the partition
Available
Displays space available for Boot Partition.
FileVault 2 State
Displays the FileVault 2 State of the partition
This value will be reported as “Unknown” when:
  • Inventory has not been updated since the last JSS upgrade
  • The JSS is unable to detect encryption status due to an error
Core Storage Partition Scheme
Displays the core storage partition scheme of the partition
Disk Encryption Category
FileVault 2 Partition Encryption State
Individual Recovery Key Validation
Displays whether the individual recovery key on a computer matches the individual recovery key stored for that computer in the JSS
  • macOS version is 10.8 or earlier
  • No recovery key in the JSS to validate against
Institutional Recovery Key
Disk Encryption Configuration
FileVault 2 Enabled Users
Displays the usernames of FileVault 2-enabled users on the computer
Peripherals Category
Displays a list of peripherals associated with the computer
Licensed Software Category
Displays a list of licensed software titles installed on the computer
Applications Category
Displays a list of applications installed on the computer
Fonts Category
Displays a list of fonts installed on the computer
Plug-ins Category
Displays a list of plug-ins installed on the computer
Profiles Category
Displays a list of profiles installed on the computer
iBeacon Regions Category
Displays a list of iBeacon regions that the computer is currently in. (This category is only displayed if the Computer Inventory Collection settings are configured to monitor iBeacon regions. For more information, see Computer Inventory Collection Settings.)
Certificates Category
Displays a list of certificates installed on the computer
Package Receipts Category
Displays a list of packages installed by Installer.app or Software Update, and a list of packages installed or cached by the Casper Suite
Software Updates Category
Displays a list of software updates available for the computer
Local User Accounts Category
Displays a list of local user accounts and information about them
Printers Category
Displays a list of printers mapped to the computer and information about those printers
Services Category
Displays a list of active services
Attachments Category
Displays a list of files attached to the inventory record
Upload and delete attachments
Viewing Inventory Information for a Computer
  1. Log in to the JSS with a web browser.
  3. Perform a simple or advanced computer search.
    For more information, see Simple Computer Searches or Advanced Computer Searches.
  4. Click the computer you want to view information for.
    If you performed a simple search for an item other than computers, you must click Expand images/download/thumbnails/15182254/Add_icon.png next to an item to view the computers related to that item.
    The computer's inventory information is displayed.
  5. Use the categories to view information for the computer.
  4. Click the computer you want to edit information for.
    If you performed a simple search for an item other than computers, you must click Expand images/download/thumbnails/15182254/Add_icon.png next to an item name to view the computers related to that item.
  5. Select the category that contains the information you want to edit and click Edit.
  6. Make changes as needed.
    If you are editing purchasing information, you can click Search images/download/thumbnails/15182254/Search_icon.png to look up and populate information from Apple's Global Service Exchange (GSX).
    Note: This button is only displayed if you have a GSX connection set up in the JSS.
    If you are editing user and location information, the changes are applied in the Users tab. This specified information is also applied in the inventory information for mobile devices, peripherals, and other computers that the user is assigned to. (For information on assigning a user to a computer or removing a user assignment, see User Assignments.)
  7. Click Save.
