VPP Code Distribution for Mobile Devices
The Jamf Software Server (JSS) allows you to distribute App Store apps, VPP store apps (including custom B2B apps), and eBooks purchased through Apple's Volume Purchase Program (VPP) to mobile devices by distributing redeemable VPP codes. When you distribute apps or eBooks using VPP codes, you can track VPP code redemption.
To distribute an app or eBook to mobile devices using VPP codes, you need an Excel spreadsheet
(.xls) that contains VPP codes for the app or eBook.
For more information on VPP, visit one of the following websites:
Note: As an alternative to VPP code distribution, The JSS also supports device-based VPP-managed distribution for mobile devices and user-based VPP-managed distribution for users. For more information, see VPP-Managed Distribution for Mobile Devices and User-Based VPP Assignments.
For information on distributing App Store apps and VPP store apps to mobile devices using redeemable VPP codes, see App Store Apps.
For information on distributing eBooks to mobile devices using redeemable VPP codes, see eBooks Available in the iBooks Store.
