Simple VPP Content Searches for Mobile Devices
A simple VPP content search functions like a search engine, allowing you to quickly search the mobile device apps and eBooks in the Jamf Software Server (JSS) for a general range of results.
VPP content searches are based on the name of the app or eBook you are searching for.
Simple VPP content search results display the following information:
  • Name of the app or eBook
  • VPP account used to purchase the content
  • Type of content
  • Total content that has been purchased with the VPP account
  • Number of apps or eBooks assigned to mobile devices, computers, or users
  • Number of VPP assignments that the content is associated with
Search Syntax
This section explains the syntax to use for the following search functions:
  • Wildcard searches
  • Including multiple search terms
  • Excluding a search term
  • Returning all content
In general, searches are not case-sensitive.
Note: The default search preference is “Exact Match”. For most items, the option can be changed to either “Starts with” or “Contains”. (For more information about configuring account preferences, see JSS User Accounts and Groups.)
Wildcard Searches
Asterisks (*) function as wildcard characters in simple searches. The following table explains the different ways asterisks can be used to refine a search:
Usage
Example
Use an asterisk after a search term to return all results with attributes that begin with that term.
Perform a search for “key*” to return all content with names that begin with “key”.
Use an asterisk before a search term to return all results with attributes that end with that term.
Perform a search for “*note” to return all content with names that end with “note”.
Use an asterisk before and after a search term to return all results that include that term.
Perform a search for “*ABC*” to return all content that includes “ABC”.
Use an asterisk without any other terms to return all results for the item you are searching.
Perform a search for “*” to return all content.
Including Multiple Search Terms
Use multiple search terms separated by a comma (,) to return all results that include those search terms.
For example, perform a user search for “key*, *note” to return all content that begins with “key” and ends with “note”.
Excluding a Search Term
Use a hyphen (-) before a search term to exclude results that include the term.
For example, perform a user search for “ABC*, -*note” to return all content with names that begin with “ABC” except for those that end with “note”.
Returning All Content
There are two ways to return all content: use an asterisk (*) without any other characters or terms, or perform a blank search.
Performing a Simple VPP Content Search
  1. Log in to the JSS with a web browser.
  2. Click Mobile Devices at the top of the page.
  3. Click Search VPP Content.
  4. Enter one or more search terms in the field provided.
    For information on the syntax to use to refine your search, see Search Syntax.
  5. Press the Enter key.
Viewing the Mobile Devices that Content is Assigned To
You can view the mobile devices that content is assigned to.
    A list of content is displayed.
  6. To view the mobile devices that the content is assigned to, click the number displayed in the In Use column.
    The mobile devices that have the content assigned to them are listed on the Mobile Devices pane.
Viewing the VPP Assignments that Content is Associated With
You can view the VPP assignments that content is associated with.
  6. To view the VPP assignments that the content is associated with, click the number displayed in the VPP Assignments column.
Related Information
