QuickAdd Packages Created Using Recon.exe
You can use Recon.exe to create a QuickAdd package (.msi) that enrolls Windows computers when it is installed. This type of QuickAdd package can be deployed using almost any deployment tool. You can also give the QuickAdd package created using Recon.exe to users to install.
When you create a QuickAdd package using Recon.exe, you can change the account that the QuickAdd package uses to authenticate to the JSS. You can also create a schedule for collecting inventory from Windows computers enrolled using the QuickAdd package.
Creating a QuickAdd Package Using Recon.exe
  1. Open Recon.exe and authenticate to the JSS.
  2. Click QuickAdd Package images/download/thumbnails/15176051/R_QuickAdd_Package.png .
  3. To change the account that the QuickAdd package uses to authenticate to the JSS, click Change and enter credentials for the account. Then click OK.
    images/download/thumbnails/15176051/Create_QuickAdd_Package.png
  4. To create a schedule for collecting inventory, click Schedule ongoing inventory updates. Configure the schedule and click Save.
  5. Click Create and save the package.
After creating the QuickAdd package, you can deploy it or give it to users to install. When the QuickAdd package is installed on computers, they are enrolled with the JSS.
