Performing Mass Actions for Computers
Mass actions allow you to perform potentially tedious tasks for multiple computers at the same time. You can use the JSS to perform the following mass actions:
  • Edit the building or department.
  • Edit the site.
  • Edit the management account.
  • Look up and populate purchasing information from Apple's Global Service Exchange (GSX).
  • Send a mass email to users.
  • Edit Autorun data.
  • Delete Autorun data.
  • Delete the computers from the JSS.
  • Send remote commands.
Mass actions can be performed on smart or static group membership lists, computer search results, or lists of license usage matches.
Mass Editing the Building or Department for Computers
Mass editing the building or department for computers allows you to add the computers to a building or department or change the building or department they belong to.
  1. Log in to the JSS with a web browser.
  3. Do one of the following:
  4. At the bottom of the list, click Action.
  5. Select Edit the Building and Department.
    This option is only displayed if there are one or more buildings or departments in the JSS. (For more information, see Buildings and Departments.)
  6. Follow the onscreen instructions to edit the building or department.
Mass Editing the Site for Computers
Mass editing the site for computers allows you to add the computers to a site or change the site they belong to.
  5. Select Edit the Site.
    This option is only displayed if there are one or more sites in the JSS. (For more information, see
    Sites.)
  6. Follow the onscreen instructions to edit the site.
    Note: When computers are added to a site, any users assigned to those computers are also added to that site.
Mass Editing the Management Account for Computers
Mass editing the management account for computers allows you to change the username and password for the computers’ management accounts. This can be useful when the management account is from a directory service and has been changed.
Mass editing the management account updates the username and password in the JSS, not on the computers.
  5. Select Edit the Management Account Information.
  6. Follow the onscreen instructions to edit the management account.
Mass Looking up and Populating Purchasing Information for Computers
You can mass look up purchasing information from Apple’s Global Service Exchange (GSX) and populate the information in the JSS if desired.
This requires a GSX connection set up in the JSS. (For more information, see Integrating with GSX.)
Note: You can only perform mass actions from a simple computer search if you searched by computers.
  5. Select Look up Purchasing Information from GSX.
    This option is only displayed if there is a GSX connection set up in the JSS.
  6. Follow the onscreen instructions to look up and populate the purchasing information.
Sending a Mass Email to Computer Users
You can send a mass email to users associated with the computers in the JSS. The email is sent to the email address associated with each computer.
This requires an SMTP server set up in the JSS. (For more information, see Integrating with an SMTP Server.)
  5. Select Send Email.
    This option is only displayed if there is an SMTP server set up in the JSS.
  6. Follow the onscreen instructions to create and send the email.
Mass Editing Autorun Data
You can mass edit Autorun data for computers.
  5. Select Edit Autorun Data.
  6. Follow the onscreen instructions to edit the Autorun data.
Mass Deleting Autorun Data
You can mass delete Autorun data for computers.
  5. Select Delete Autorun Data.
    This option is only displayed if there is Autorun data in the JSS.
  6. Follow the onscreen instructions to delete the Autorun data.
Mass Deleting Computers
You can mass delete computers from the JSS.
  5. Select Delete Computers.
  6. Follow the onscreen instructions to delete the computers.
Mass Sending Remote Commands to Computers
You can mass send the Lock Device and Update OS Version remote command to computers.
The remote commands available for a particular computer vary depending on the computer's OS version. For more information, see the following sections in this guide:
  5. Select Send Remote Commands.
  6. Select the remote command to send to computers.
  7. Follow the onscreen instructions to send the remote command.
Related Information
Removing Jamf Components from Computers
Find out how to remove all Casper Suite-related components from computers that have been deleted from the JSS.
