Mobile Device Reports
The data displayed in smart or static group membership lists or mobile device search results can be exported from the Jamf Software Server (JSS) to the following file formats:
  • Comma-separated values file (.csv)
  • Tab delimited text file (.txt)
  • XML file
You can change the way the data is organized by basing the export on any of the following inventory items:
  • Mobile devices
  • Mobile device groups
  • Apps
  • Configuration profiles
  • Certificates
  • Provisioning profiles
The data is displayed in alphanumeric order by the selected inventory item.
Creating Mobile Device Reports
  1. Log in to the JSS with a web browser.
  2. Click Mobile Devices at the top of the page.
  3. Do one of the following:
  4. At the bottom of the list, click Export.
  5. Follow the onscreen instructions to export the data.
The report downloads immediately.
