Local Enrollment Using Recon.exe
If you have physical access to the Windows computer that you want to enroll, you can run Recon.exe locally on the computer. This allows you to submit detailed inventory information for the computer.
Enrolling a Windows Computer by Running Recon.exe Locally
  1. On the computer you want to enroll, open Recon.exe and authenticate to the JSS.
  2. (Optional) Enter an asset tag and/or use a barcode scanner to enter bar codes.
    The computer name is populated by default.
    images/download/attachments/15175959/Computer_Information.png
  3. (Optional) Click the User and Location tab and specify user and location information for the computer.
    If an LDAP server is set up in the JSS, click Check Name to populate information from the LDAP server.
    images/download/attachments/15175959/User_and_Location.png
  4. (Optional) Click the Purchasing tab and specify purchasing information for the computer.
    images/download/attachments/15175959/Purchasing.png
  5. (Optional) Click the Extension Attributes tab and specify information as needed.
  6. (Optional) Click the Peripherals tab and add peripherals as needed.
    images/download/thumbnails/15175959/Add_Peripheral.png
  7. Click Submit.
    images/download/attachments/15175959/Peripherals.png
