JSS Objects
JSS objects provide the foundation for performing administrative and management tasks using the Jamf Software Server (JSS). Examples of JSS objects include policies, configuration profiles, and network segments.
For detailed information about a specific JSS object, including instructions for navigating to the JSS object, see the appropriate section in this guide. Common actions that can be taken on JSS objects are cloning, editing, deleting, and viewing history.
Note: Available actions are dependent on the particular JSS object. (For example, a package cannot be cloned, so the Clone button is not displayed for the Packages object.) In addition, an action will not be available if the required privileges have not been granted for that JSS object.
Cloning a JSS Object
  1. Log in to the JSS with a web browser.
  2. Navigate to the JSS object you want to clone.
  3. Click Clone and make changes as needed.
  4. Click Save.
Editing a JSS Object
  2. Navigate to the JSS object you want to edit.
  3. Click Edit and make changes as needed.
  4. Click Save.
Deleting a JSS Object
  2. Navigate to the JSS object you want to delete.
  3. Click Delete.
  4. Click Delete again to confirm.
Viewing the History of a JSS Object
The JSS allows you to view the history of each JSS object. The information you can view includes:
  • The date/time the JSS object was created or edited
  • The username of the administrator who made the change
  • Notes associated with the changes
  • Details about a change
Note: This information is displayed for any JSS object changes made using v9.31 or later.
  2. Navigate to the JSS object you want to view the history of.
  3. Click History.
  4. (Optional) Click Add Note to add a note to the history record.
  5. (Optional) Click Details to view details about a change.
