Computer Management Capabilities
The Casper Suite can be used to enroll and manage Mac computers. The management capabilities available for computers vary depending on the macOS version.
For information on the requirements for managing computers, see Requirements.
Management Capabilities for Computers
The following table provides an overview of the management capabilities available with the Casper Suite for computers by macOS version:
macOS Version
10.7
10.8
10.9
10.10
10.11
10.12
Enrollment
Via user-initiated enrollment
images/download/thumbnails/11272232/checkmark.png
Via QuickAdd package created using Recon
Via the network scanner1
Via remote enrollment using Recon2
Via local enrollment using Recon
Via Apple's DEP using a PreStage enrollment3
Via imaging using Casper Imaging
Inventory
Submit inventory to the JSS
Extension attributes
Simple searches
Advanced searches
Computer reports
Mass actions
Computer Groups
Static groups
Smart groups
Self Service
Self Service
Display badges on the Self Service icon in the Dock
Display notifications in Notification Center
Software Distribution
VPP-managed distribution for computers
VPP-managed distribution for users
Mac App Store apps
Install packages
Remote Control
Screen sharing4
Configuration
macOS configuration profiles
Run scripts
Administer printers
Administer Dock items
Administer local accounts5
Administer the management account6
Bind to directory services
Deploy disk encryption configuration
Issue a new FileFault 2 recovery key
Administer open Firmware or EFI passwords
Perform an authenticated restart on FileVault 2-enabled computers7
images/download/thumbnails/11272232/checkmark0.png
Remote Commands for Computers
Lock computer
Remove MDM profile
Wipe computer
Send blank push
Update OS version and built-in apps8
Usage Management
View Application Usage logs
View Computer Usage logs
Restrict software
eBook Distribution
Install ePub file
Install iBooks file
Install PDF
Notes:
1. To enroll computers using the network scanner, SSH (Remote Login) must be enabled on the computers.
2. To enroll a computer by running Recon remotely, you need the IP address of the computer and SSH (Remote Login) must be enabled on the computer.
3. When computers with macOS 10.10 or later are enrolled using a PreStage enrollment, they are also automatically managed if user-initiated enrollment is enabled for macOS in the JSS.
4. If the target computer has macOS 10.10 or later, screen sharing must also be enabled on the computer.
5. To enable or disable an account for FileVault 2, the computer must have macOS 10.9 or later.
6. To enable or disable the management account for FileVault 2, the computer must have macOS 10.9 or later.
7. To perform an authenticated restart, the target computer must have macOS 10.8.2 or later and be FileVault 2-enabled.
8. Requires enrollment via a PreStage enrollment.
