Understanding Managed eBooks
The Jamf Software Server (JSS) allows you to manage eBooks that are distributed to iOS devices. When an eBook is managed by the JSS, you have more control over distribution and removal of the eBook. The following table provides more detail:
Unmanaged eBooks
(iOS and macOS)
Managed eBooks
(iOS only)
Distribution Methods
Make available in Self Service
images/download/thumbnails/16429912/checkmark.png
Install automatically/prompt users to install
Removal Options
Remove from Self Service
Remove in-house eBooks from mobile devices
Remove from computers
Remove in-house eBooks when MDM profile is removed
Managed eBook Requirements
The following requirements determine whether an eBook can be managed by the JSS:
  • The device has iOS 8 or later
  • The eBook is an in-house eBook, or an eBook available in the iBooks Store that is free or paid for by the organization using Apple's Volume Purchase Program (VPP) and assigned to the user via VPP-managed distribution (For information, see User-Based VPP Assignments.)
If you try to make an eBook managed and these requirements are not met, the eBook behaves as unmanaged.
