Startup Script
The Startup Script settings in the Jamf Software Server (JSS) allow you to create a startup script on computers and use it to perform the following actions at startup:
  • Log Computer Usage information (date/time of startup).
  • Check for policies triggered at startup.
  • Enable computer-level Managed Preferences.
  • Ensure SSH (Remote Login) is enabled on computers.
Configuring the Startup Script
  1. Log in to the JSS with a web browser.
  2. In the top-right corner of the page, click Settings images/download/thumbnails/16419934/Settings_icon.png .
  3. Click Computer Management.
  4. In the “Computer Management–Management Framework” section, click Check-In images/download/thumbnails/16419934/Check-In.png .
  5. Click the Startup Script tab.
  6. Click Edit.
  7. Configure the settings on the pane.
  8. Click Save.
Related Information
  • Computer Usage
    Find out how to view Computer Usage information logged at startup.
  • Managing Policies
    You can create policies that are triggered at startup.
  • Managed Preferences
    Learn about computer-level Managed Preferences and how to create Managed Preferences, in general.
Components Installed on Managed Computers
Find out where the startup script is stored on computers.
