PKI Certificates
The PKI Certificates settings allow you to manage the certificate lifecycle directly in the Jamf Software Server (JSS). To ensure secure communication with the Apple Push Notification service (APNs), the JSS requires a public key infrastructure (PKI) that supports certificate-based authentication. The PKI must include the following components:
  • A certificate authority (CA)
  • A signing certificate
  • A CA certificate
For more information on PKI and its components, see Security.
You can choose to use a built-in CA, integrate with a trusted third-party CA (Symantec), or configure your own PKI if you have access to an external CA that supports the Simple Certificate Enrollment Protocol (SCEP).
The PKI Certificates settings in the JSS allow you to perform the following tasks:
  • View a list of active, expiring, inactive or all certificates issued by a CA.
  • Add a PKI certificate authority to the JSS Dashboard.
  • View details of a specific certificate that was issued.
  • Export a certificate list for a CA.
Using the Built-in CA
There is no configuration necessary to use the built-in CA—the signing and CA certificates are created and stored for you. The built-in CA is used by default to issue certificates to both computers and mobile devices.
You can use the PKI Certificates settings in the JSS to perform the following tasks related to the built-in CA:
  • Download the built-in CA certificate.
  • View and revoke certificates issued by the built-in CA.
  • Create certificates using a Certificate Signing Request (CSR).
  • Create a backup of the built-in CA certificate.
Downloading the Built-in CA Certificate
You can use the PKI Certificates settings in the JSS to download the CA certificate issued by the built-in CA.
Note: The CA certificate issued by the built-in CA is also stored in the System keychain in Keychain Access.
  1. Log in to the JSS with a web browser.
  2. In the top-right corner of the page, click Settings images/download/thumbnails/16432967/Settings_icon.png .
  3. Click Global Management.
  4. Click PKI Certificates images/download/thumbnails/16432967/PKI.png .
  5. Click the Management Certificate Template tab, and then click Built-in CA.
  6. Click Download CA Certificate.
The certificate (.pem) downloads immediately.
Viewing or Revoking Built-in CA Certificates
You can view the following information for a certificate issued by the built-in CA:
  • Subject name
  • Serial number
  • Device name associated with the certificate
  • Username associated with certificate
  • CA configuration name
  • Date/time issued
  • Expiration date/time
  • Status
  • Date/time revoked (if applicable)
You can also revoke a certificate issued by the built-in CA.
Warning: Revoking a certificate stops communication between the JSS and the computer or mobile device that the certificate was issued to. You will need to re-enroll the computer or device to restore communication.
  5. To view a list of Expiring, Active, Inactive or All certificates, click the number displayed in the corresponding column on the Certificate Authorities pane.
    A list of certificates issued by the built-in CA is displayed.
  6. Click the certificate subject of the certificate you want to view or revoke.
    Information about the certificate is displayed.
  7. To revoke the certificate, click Revoke.
    The status of the certificate is changed to Revoked.
  8. Click Done to return to the list of built-in certificates.
Manually Creating a Built-in CA Certificate from a CSR
Depending on your environment, you may need to manually create a certificate from a certificate signing request (CSR). For example, you may need to do this if you have a clustered environment with Tomcat configured for working behind a load balancer. You can create this certificate using the PKI Certificates settings in the JSS.
Note: The certificate created from the CSR is intended solely for purposes of communication between the JSS and a managed computer or mobile device.
To create a certificate from a CSR, you need a request in Base64-encoded PEM format.
  6. Click Create Certificate from CSR.
  7. In the CSR field, paste the CS R.
    The request must begin with
    ----BEGIN CERTIFICATE REQUEST----
    and end with
    ----END CERTIFICATE REQUEST----
  8. Click Create.
    The certificate (.pem) is downloaded immediately.
  9. Click Back to return to the Built-in CA pane.
Creating a Backup of the Built-in CA Certificate
It is recommended that you create a password-protected backup of the CA certificate issued by the built-in CA and store it in a secure location.
  6. Click Create CA Backup.
  7. Create and verify a password to secure the backup of the built-in CA certificate.
    You will need to enter this password to restore the certificate backup.
  8. Click Create Backup.
    The backup file (.p12) is downloaded immediately.
Integrating with a Symantec CA
In the JSS, you can add Symantec as a certificate authority. Symantec certificates are managed in the JSS using the Symantec Managed PKI service.
Use the PKI Certificates settings in the JSS to perform the following tasks related to the Symantec CA:
  • Configure Symantec as a PKI provider.
  • View or refresh Symantec certificates.
  • Export Symantec certificates.
Once communication with Symantec is successfully established, you can define which certificate to deploy to computers or mobile devices. For more information on how to issue Symantec certificates to computer and mobile devices, see the following Knowledge Base article:
Issuing Symantec Certificates to Computers and Mobile Devices in the JSS
Note: Inventory information for a user must be complete to properly issue a Symantec certificate to a computer or mobile device. Symantec certificates will not be issued or issued with missing attributes if there is incomplete data in inventory information for a user in the JSS.
Requirements
To integrate with Symantec as a CA, you need:
  • Symantec Managed PKI service
  • Web browser with Symantec PKI Client
  • Administrator certificate from Symantec added to your local keychain
Configure Symantec as a PKI Provider
Adding Symantec as a PKI Provider allows you to add Symantec certificates in the JSS and issue them to computers and mobile devices.
  5. Click the Certificate Authority tab, and then click Configure New Certificate Authority.
  6. Select Symantec. Follow the onscreen instructions to configure Symantec as the PKI provider.
The newly configured CA is listed on the Certificate Authorities pane.
View or Refresh Symantec Certificates
You can view the following information for a certificate issued by Symantec:
  • Subject name
  • Serial number
  • Device name associated with certificate
  • CA Configuration name
  • Date/time issued
  • Status
  • Configuration profiles associated with the certificate
In the JSS, you can also refresh the status of a certificate issued by Symantec. Refreshing a certificate starts communication between the JSS and Symantec to display the current status of the certificate.
    A list of certificates issued by Symantec is displayed.
  6. Click on the certificate subject of the certificate you want to view.
  7. To refresh the certificate status, click Refresh Certificate Status.
    The status of the certificate is displayed as Active, Revoked or Expired.
  8. Click Done to return to the list of certificates.
Export Symantec Certificates
The Symantec certificates displayed in PKI Certificates can be exported from the JSS to the following file formats:
  • Comma-separated values file (.csv)
  • Tab delimited text file (.txt)
  • XML file
    A list of all certificates issued by Symantec is displayed.
  6. Click Export.
  7. Select the appropriate file format to use for the export and click Next.
    The export begins immediately.
  8. Once the certificates have been exported, click Done.
Integrating with an External CA
If you are using an organizational or third-party CA that supports SCEP, you can use it to issue management certificates to computers and mobile devices.
Integrating an external CA with the JSS involves the following steps:
  • Specify SCEP parameters for the external CA.
  • Upload a signing certificate and CA certificate for the external CA.
Note: If you need to make changes to your organizational or third-party CA in the JSS, it is recommended that you contact Jamf Support. Changes to the PKI could lead to re-enrolling the mobile devices in your environment.
Specifying SCEP Parameters for an External CA
  5. Click the Management Certificate Template tab, and then click External CA.
  6. Click Edit.
  7. Select the Use External Certificate Authority checkbox.
  8. Use the External CA pane to specify SCEP parameters.
  9. Choose the type of challenge password to use from the Challenge Type pop-up menu:
    • If you want all computers and mobile devices to use the same challenge password, choose “Static” and specify a challenge password.
      The challenge password will be used as the pre-shared secret for automatic enrollment.
    • If you are using a non-Microsoft CA and you want each computer and mobile device to use a unique challenge password, choose “Dynamic”.
      The Dynamic challenge type requires use of the JSS API and membership in the Jamf Software Developer Program. Before selecting this option, contact your Technical Account Manager to learn more about the Jamf Software Developer Program and the additional steps you need to take to use this option.
    • If you are using a Microsoft CA and you want each computer and mobile device to use a unique challenge password, choose “Dynamic-Microsoft CA”.
    Note: If you choose the “Dynamic” or “Dynamic-Microsoft CA” challenge type, you must use user-initiated enrollment to enroll computers and mobile devices so that a unique challenge password is used for each device. For more information, see User-Initiated Enrollment for Computers and User-Initiated Enrollment for Mobile Devices.
  10. Click Save.
Uploading Signing and CA Certificates for an External CA
To integrate an external CA with the JSS, you need to provide the signing and CA certificates for the external CA. This is done by uploading a signing certificate keystore (.jks or .p12) to the JSS that contains both certificates.
Note: By default, the JSS uses the signing and CA certificates for the JSS’s built-in CA. You must replace these certificates with the ones for the external CA when you initially set up the integration.
An assistant guides you through the process of uploading the keystore that contains the signing and CA certificates.
  6. At the bottom of the E xternal CA pane, click Change Signing and CA Certificates.
  7. Follow the onscreen instructions to upload the signing and CA certificates for the external CA.
Related Information
Push Certificates
Learn how to create a push certificate and upload it to the JSS so the JSS can communicate with Apple Push Notification service (APNs).
