Mobile Device Extension Attributes
Mobile device extension attributes are custom fields that you can create to collect almost any type of data from a mobile device.
Note: Mobile device extension attributes do not apply to personally owned mobile devices.
When you create a mobile device extension attribute, you specify the following information:
  • Type of data being collected, such as string, integer, or date
  • Inventory category in which to display the extension attribute in the JSS, such as Hardware or Purchasing
  • Input type, which determines how the extension attribute is populated with data
Extension attributes can add time and network traffic to the inventory process depending on the type of data you choose to collect and the input type used to collect it.
Mobile Device Extension Attribute Input Types
You can choose to populate the value of a mobile device extension attribute using any of the following input types:
  • Text field—This displays a text field in mobile device inventory information that you can enter a value into. Only extension attributes created manually can be populated using a text field.
  • Pop-up menu—This displays a pop-up menu in mobile device inventory information from which you can choose a value. Only extension attributes created manually can be populated using a pop-up menu.
  • LDAP Attribute Mapping—This populates the extension attribute with the value for an LDAP attribute. It also generates a variable that can be used to populate configuration profile settings with values for the LDAP attribute. The variable is $EXTENSIONATTRIBUTE_<#>, where <#> is the extension attribute ID. For more information on payload variables for configuration profiles, see Mobile Device Configuration Profiles.
Requirements
To create a mobile device extension attribute with the “LDAP Attribute Mapping” input type, you need:
Creating a Mobile Device Extension Attribute
  1. Log in to the JSS with a web browser.
  2. In the top-right corner of the page, click Settings images/download/thumbnails/16429095/Settings_icon.png .
  3. Click Mobile Device Management.
  4. Click Extension Attributes images/download/thumbnails/16429095/Extension_Attributes.png .
  5. Click New images/download/thumbnails/16429095/New_icon.png .
  6. Configure the settings on the pane.
  7. Click Save.
If the extension attribute has the “LDAP Attribute Mapping” input type, the LDAP attribute variable is displayed on the pane.
Related Information
