Managing Disk Encryption Configurations
Creating a disk encryption configuration in the Jamf Software Server (JSS) is the first step to activating FileVault 2 on computers with macOS 10.8 or later.
When you create a disk encryption configuration, you specify the following information:
  • The type of recovery key to use for recovering encrypted data. There are three recovery key options you can choose from:
    • Individual (also known as “Personal”)—Uses a unique alphanumeric recovery key for each computer. The individual recovery key is generated on the computer and sent back to the JSS for storage when the encryption takes place.
    • Institutional—Uses a shared recovery key. This requires you to create the recovery key with Keychain Access and upload it to the JSS for storage.
    • Individual and Institutional—Uses both types of recovery keys.
  • The user for which to enable FileVault 2
    • Management Account—Makes the management account on the computer the enabled FileVault 2 user.
      Note: If you make the management account the enabled FileVault 2 user on computers with macOS 10.9 or later, you will be able to issue a new recovery key to those computers later if necessary. (For more information, see Issuing a New FileVault 2 Recovery Key.)
    • Current or Next User—Makes the user that is logged in to the computer when the encryption takes place the enabled FileVault 2 user. If no user is logged in, the next user to log in becomes the enabled FileVault 2 user.
Requirements
To use either the “Institutional” recovery key or the “Individual and Institutional” recovery key options in the disk encryption configuration, you must first create and export a recovery key using Keychain Access. (For more information, see the Creating and Exporting an Institutional Recovery Key Knowledge Base article.)
Creating a Disk Encryption Configuration
  1. Log in to the JSS with a web browser.
  2. In the top-right corner of the page, click Settings images/download/thumbnails/16433281/Settings_icon.png .
  3. Click Computer Management.
  4. In the “Computer Management” section, click Disk Encryption Configurations images/download/thumbnails/16433281/Disk_Encryption_Configurations.png .
  5. Click New images/download/thumbnails/16433281/New_icon.png .
  6. Configure the disk encryption configuration using the fields and options on the pane.
  7. Click Save.
Related Information
Deploying Disk Encryption Configurations
Find out how to activate FileVault 2 by deploying a disk encryption configuration using a policy or Casper Remote.
