Managed Preferences
Managed Preferences are manifest files that define preferences for computers and users. You can use the Jamf Software Server (JSS) to create Managed Preference profiles, which contain groups of Managed Preferences. You can also specify the users and computers for which a profile should be applied (called “scope”).
The JSS comes with manifest files for many common Managed Preferences so that you can easily add them to profiles. You can also add custom Managed Preferences by creating them manually or uploading a manifest file.
Levels for Managed Preferences
When you add a Managed Preference to a profile, you must specify a level at which to apply the preference. The level determines how and when the preference is applied. The levels available for each Managed Preference depend on the application or utility for which you are defining the preference.
If you have applied Managed Preferences using Apple’s Workgroup Manager, the level names in the JSS may be unfamiliar to you. The following table shows each level, its Workgroup Manager equivalent, when and how it is applied, and whether it is available for some or all Managed Preferences.
JSS Levels
Workgroup Manager
Levels
Applied at
Available for
User-level enforced
Always
Login with a login hook
Some Managed Preferences
User-level at every login
Often
All Managed Preferences
User-level at next login only
Once
Computer-level enforced
Always (Applied to a computer object)
Reboot with a startup script
Unmanaged
Unset
Login or reboot
Compatibility with Third-Party Providers
In macOS 10.7 or later, you can use more than one provider to apply Managed Preferences. In some cases, Managed Preferences applied using the JSS can interfere with or be interfered with by Managed Preferences from a third-party provider.
The following table shows the compatibility of Managed Preferences applied using the JSS and tested third-party providers.
Local Home
Directory
Network Home
Directory
Mobile Home
Directory
Microsoft's Active Directory
Compatible
Compatible
Compatible
Apple's Open Directory
Compatible
Compatible
Compatible
PowerBroker Identity Services
(formerly called “Likewise”)
Compatible
N/A
Incompatible
ADmitMac
Compatible
Compatible
Incompatible
Centrify
Compatible
N/A
Incompatible
Requirements
To apply user-level Managed Preferences, they must be enabled in the Login/Logout Hooks settings in the JSS. (For more information, see Login and Logout Hooks.)
To apply computer-level Managed Preferences, they must be enabled in the Startup Script settings in the JSS. (For more information, see Startup Script.)
Creating a Managed Preference Profile
  1. Log in to the JSS with a web browser.
  3. Click Managed Preferences.
  4. Click New images/download/thumbnails/16429196/New_icon.png .
  5. Use the General payload to configure basic settings for the profile.
  6. Use the rest of the payloads to configure the Managed Preferences you want to apply.
  7. (Optional) Manually create a custom Managed Preference:
    1. Select the Custom payload.
    2. Click Add images/download/thumbnails/16429196/Add_icon.png for Manual Setting.
    3. Configure the Managed Preference using the options on the pane.
  8. (Optional) Upload a manifest file:
    2. Click Add images/download/thumbnails/16429196/Add_icon.png for Upload Manifest.
    3. Upload the manifest file.
  9. Click the Scope tab and configure the scope of the profile.
    For more information, see Scope.
  10. Click Save.
The profile is applied the next time computers in the scope check in with the JSS.
Related Information
For related information, see the following section in this guide.
Viewing Managed Preferences for a Computer
Find out how to view managed preferences for a computer or user.
