Login and Logout Hooks
The Login/Logout Hooks settings in the Jamf Software Server (JSS) allow you to create login and logout hooks on computers and use them to perform the following actions:
  • Log Computer Usage information (username and date/time) at login and logout.
  • Check for policies triggered at login or logout.
  • Enable user-level and user-level enforced Managed Preferences at login.
  • Hide the Restore partition at login.
Warning: Creating login and logout hooks with the Casper Suite can disable existing login and logout hooks.
Configuring Login and Logout Hooks
  1. Log in to the JSS with a web browser.
  2. In the top-right corner of the page, click Settings images/download/thumbnails/16432814/Settings_icon.png .
  3. Click Computer Management.
  4. In the “Computer Management–Management Framework” section, click Check-In images/download/thumbnails/16432814/Check-In.png .
  5. Click the Login/Logout Hooks tab.
  6. Click Edit.
  7. Configure the settings on the pane.
  8. Click Save.
Related Information
  • Computer Usage
    Find out how to view Computer Usage information logged at login and logout.
  • Managing Policies
    You can create policies that are triggered at login or logout.
  • Managed Preferences
    Learn about user-level Managed Preferences and how to create Managed Preferences, in general.
Components Installed on Managed Computers
Find out where login/logout hooks are stored on computers.
