Jamf Push Proxy
The Jamf Push Proxy enables communication between the Jamf Software Server (JSS) and devices with Self Service Mobile for iOS installed, and between the JSS and personally owned Android devices. Push notifications trigger the following types of communication between the JSS and devices in your environment:
  • Sending Notification Center notifications to mobile devices with Self Service Mobile for iOS
  • Requesting management check-ins from personally owned Android devices
The JSS requires a valid proxy server token to authenticate to the Jamf Push Proxy. An assistant in the JSS guides you through the process to request a new proxy server token from the Jamf Authorization Server and upload it to the JSS.
Requirements
To request or renew a proxy server token, you need a valid Jamf Nation account.
To create a Jamf Nation account, go to:
https://www.jamf.com/jamf-nation/users/new
Requesting and Uploading a Proxy Server Token
  1. Log in to the JSS with a web browser.
  2. In the top-right corner of the page, click Settings images/download/thumbnails/16428502/Settings_icon.png .
  3. Click Global Management.
  4. Click Push Certificates images/download/thumbnails/16428502/Push_Certificates.png .
  5. Click New images/download/thumbnails/16428502/New_icon.png .
  6. Select Get proxy server token from Jamf Authorization Server.
  7. Follow the onscreen instructions to get the proxy server token and upload it to the JSS.
Renewing the Proxy Server Token
Note: The proxy server token will be renewed automatically, however, the following steps can be used for troubleshooting purposes.
  5. Click the push proxy and then click Renew.
Related Information
Jamf Push Proxy Communication
Learn about push proxy network communication and ports.
