JSS URL
The JSS URL is the URL that client applications, computers, and mobile devices connect to when communicating with the Jamf Software Server (JSS). You can view and configure the JSS URL in the JSS.
Important: In general, you should not change the JSS URL in a production environment with managed computers and mobile devices. If the JSS URL is incorrect or not specified, client applications, computers, and mobile devices are unable to connect to the server.
You can also view or configure the JSS URL that’s used for enrolling mobile devices with an enrollment profile and Apple’s iPhone Configuration Utility (iPCU).
Note: If your environment is hosted in Jamf Cloud, the JSS URL setting is managed by Jamf Cloud and is not accessible.
Viewing or Configuring the JSS URLs
  1. Log in to the JSS with a web browser.
  2. In the top-right corner of the page, click Settings images/download/thumbnails/16432963/Settings_icon.png .
  3. Click Global Management.
  4. Click JSS URL images/download/thumbnails/16432963/JSS_URL.png .
    The JSS URLs are displayed on the pane.
  5. To configure the JSS URLs:
    1. Click Edit.
    2. Enter the new URLs in the fields on the pane.
    3. Click Save.
Related Information
Enrollment Profiles
Find out how to create and download enrollment profiles so you can enroll mobile devices by connecting them to a computer via USB.
