Advanced VPP Content Searches for Users
Advanced VPP content searches allow you to use detailed search criteria to search mobile device apps, Mac App Store apps, and eBooks in the Jamf Software Server (JSS). These types of searches give you more control over your search by allowing you to do the following:
  • Save the search.
Creating an Advanced VPP Content Search
  1. Log in to the JSS with a web browser.
  2. Click Users at the top of the page.
  3. Click Search VPP Content.
  4. Click New images/download/thumbnails/16429908/New_icon.png .
    1. Click Add images/download/thumbnails/16429908/New_icon.png .
    4. Enter a value in the Value field or browse for a value by clicking Browse images/download/thumbnails/16429908/Browse_icon.png .
  7. Choose an operator from the And/Or pop-up menu(s) to specify the relationships between criteria.
    images/download/attachments/16429908/Advanced_Content_Search_Criteria.png
  10. Click Save.
The results of a saved search are updated each time content is modified and meets or fails to meet the specified search criteria.
To view the search results, click View.
Viewing Advanced VPP Content Search Results
  4. Click the advanced VPP content search you want to view the results for.
  5. Click View.
Related Information
