Advanced User Searches
Advanced user searches allow you to use detailed search criteria to search for users in the Jamf Software Server (JSS). These types of searches give you more control over your search by allowing you to do the following:
  • Save the search.
Creating an Advanced User Search
  1. Log in to the JSS with a web browser.
  2. Click Users at the top of the page.
  3. Click Search Users.
  4. Click New images/download/thumbnails/16428533/New_icon.png .
    1. Click Add images/download/thumbnails/16428533/New_icon.png .
    4. Enter a value in the Value field or browse for a value by clicking Browse images/download/thumbnails/16428533/Browse_icon.png .
  7. Choose an operator from the And/Or pop-up menu(s) to specify the relationships between criteria.
    images/download/attachments/16428533/Advanced_User_Search.png
  10. Click Save.
The results of a saved search are updated each time user information is modified and users meet or fail to meet the specified search criteria.
To view the search results, click View.
Viewing Advanced User Search Results
  4. Click the advanced user search you want to view the results for.
  5. Click View.
Related Information
