About Distribution Points
Distribution points are servers used to host files for distribution to computers and mobile devices. The following types of files can be distributed from a distribution point using Jamf Pro:
  • Packages
  • Scripts
  • In-house apps
  • In-house books
Jamf Pro supports two types of distribution points:
  • File share distribution points
  • A cloud distribution point
You can use any combination of these types of distribution points.
By default, the first distribution point you add to Jamf Pro is the master distribution point. The master distribution point is used by all other distribution points as the authoritative source for all files during replication. You can change the master distribution point at any time.
When planning your distribution point infrastructure, it is important to understand the differences between each type of distribution point. The following table explains the key differences:
File Share Distribution Point
Cloud Distribution Point
Description
Standard server that is configured to be a distribution point
Distribution point that uses one of the following content delivery networks (CDNs) to host files:
  • Rackspace Cloud Files
  • Amazon Web Services
  • Akamai
  • Jamf Cloud Distribution Service (JCDS)
Maximum Number per Jamf Pro Instance
Unlimited
One
Server/Platform Requirements
Any server with an Apple Filing Protocol
(AFP) or Server Message Block (SMB) share
None
Protocol
AFP, SMB, HTTP, or HTTPS
HTTPS
Ports
  • AFP: 548
  • SMB: 139
  • HTTP: 80
  • HTTPS: 443
443
Authentication Options
  • AFP or SMB:
    • No authentication
    • Username and password
  • HTTP or HTTPS:
    • No authentication
    • Certificate-based authentication
None
Files that Can Be Hosted
Packages
  • Packages
  • In-house apps
  • In-house books
Parent-Child Capabilities
No
No
File Replication Method
Replication to file share distribution points must be initiated from Jamf Admin.
Replication to a cloud distribution point must be initiated from Jamf Admin.
Selective Replication
Not available when replicating to file share distribution points.
Available when replicating to a cloud distribution point if the master distribution point is a file share distribution point.
The files for replication must be specified in Jamf Pro and the replication initiated from Jamf Admin.
Related Information
