Performing Mass Actions for Mobile Devices
Mass actions allow you to perform potentially tedious tasks for multiple mobile devices at the same time. You can use Jamf Pro to perform the following mass actions:
  • Edit the building or department.
  • Edit the site.
  • Look up and populate purchasing information from Apple's Global Service Exchange (GSX).
  • Send a mass email to users.
  • Send a mass notification to mobile devices with Jamf Self Service for iOS installed.
  • Delete the mobile devices from Jamf Pro.
  • Send remote commands.
  • Cancel management commands.
Mass actions can be performed on static or smart group membership lists or mobile device search results.
Mass Editing the Building or Department for Mobile Devices
Mass editing the building or department for mobile devices allows you to add the mobile devices to a building or department or change the building or department they belong to.
  1. Log in to Jamf Pro.
  3. Do one of the following:
  4. At the bottom of the list, click Action.
  5. Select Edit the Building and Department.
    This option is only displayed if there are one or more buildings or departments in Jamf Pro. (For more information, see Buildings and Departments.)
  6. Follow the onscreen instructions to edit the building and department.
Mass Editing the Site for Mobile Devices
Mass editing the site for mobile devices allows you to add the devices to a site or change the site they belong to.
Note: Changing the site that personally owned devices belong to automatically changes the personal device profile that is used to perform management tasks on those devices. For more information, see Personal Device Profiles.
  5. Select Edit the Site.
    This option is only displayed if there are one or more sites in Jamf Pro. (For more information, see Sites.)
  6. Follow the onscreen instructions to edit the site.
    Note: When mobile devices are added to a site, any users assigned to those mobile devices are also added to that site.
Mass Looking up and Populating Purchasing Information for Mobile Devices
You can mass look up purchasing information from Apple’s Global Service Exchange (GSX) and populate the information in Jamf Pro if desired.
This requires a GSX connection set up in Jamf Pro. (For more information, see Integrating with GSX.)
Note: GSX may not always return complete purchasing information. Only the information found in GSX is returned.
  5. Select Look up Purchasing Information from GSX.
    This option is only displayed if there is a GSX connection set up in Jamf Pro.
  6. Follow the onscreen instructions to look up and populate the purchasing information.
Sending a Mass Email to Mobile Device Users
You can send a mass email to users associated with the mobile devices in Jamf Pro. The email is sent to the email address associated with each device.
This requires an SMTP server set up in Jamf Pro. (For more information, see Integrating with an SMTP Server.)
  5. Select Send Email.
    This option is only displayed if there is an SMTP server set up in Jamf Pro.
  6. Follow the onscreen instructions to create and send the email.
Sending a Mass Notification to Mobile Devices
You can send a mass notification to mobile devices.
This requires mobile devices with Jamf Self Service for iOS installed. (For more information, see Installing Jamf Self Service on Mobile Devices.)
Notifications are displayed to users in the following ways:
  • The Self Service app icon displays a badge with the number of notifications that have not been viewed by the user.
  • In Self Service, the Notifications browse button displays a badge with the number of notifications that have not been viewed by the user. Items are listed in the “Notifications” area of the app as they are added.
  • (Optional) Each notification can be configured to also display an alert and appear in Notification Center. This requires a proxy server token in Jamf Pro. (For more information, see Jamf Push Proxy.)
  5. Select Send a Notification to Mobile Devices with Jamf Self Service for iOS Installed.
  6. Follow the onscreen instructions to send the notification.
Mass Deleting Mobile Devices
You can mass delete mobile devices from Jamf Pro.
  5. Select Delete Mobile Devices.
  6. Follow the onscreen instructions to delete the mobile devices.
Mass Sending Remote Commands to Mobile Devices
You can mass send the following remote commands to mobile devices:
  • Update iOS version
  • Clear passcode
  • Update passcode lock grace period (Shared iPad only)
  • Lock device
  • Update inventory
  • Restart device
  • Wipe device
  • Unmanage Institutionally Owned Device
  • Set wallpaper
  • Enable/Disable diagnostic and usage reporting and app analytics
  • Shut down device
  • Enable/Disable Bluetooth
The remote commands available for a particular device vary depending on the device ownership type, device type, and OS version. For more information, see the following sections in this guide:
  5. Select Send Remote Commands.
  6. Select the remote command to send to mobile devices.
  7. Follow the onscreen instructions to send the remote command.
Mass Canceling Management Commands on Mobile Devices
You can mass cancel all pending or all failed management commands on mobile devices from Jamf Pro.
  5. Select Cancel Management Commands.
  6. Follow the onscreen instructions to cancel all pending or all failed management commands on the mobile devices.
Related Information
Viewing and Editing Inventory Information for a Mobile Device
Find out how to view and edit inventory information for a single mobile device.
