Advanced VPP Content Searches for Computers
Advanced VPP content searches allow you to use detailed search criteria to search Mac App Store apps and books in Jamf Pro. These types of searches give you more control over your search by allowing you to do the following:
  • Save the search.
Creating an Advanced VPP Content Search
  1. Log in to Jamf Pro.
  3. Click Search VPP Content.
  4. Click New images/download/thumbnails/17931707/Icon_New_Button.png .
    1. Click Add images/download/thumbnails/17931707/Icon_Add_Button.png .
    4. Enter a value in the Value field or browse for a value by clicking Browse images/download/thumbnails/17931707/Browse_icon.png .
  7. Choose an operator from the And/Or pop-up menu(s) to specify the relationships between criteria.
    images/download/attachments/17931707/VPP_Advanced_Search.png
  10. Click Save.
The results of a saved search are updated each time content is modified and meets or fails to meet the specified search criteria.
To view the search results, click View.
Viewing Advanced VPP Content Search Results
  4. Click the advanced VPP content search you want to view the results for.
  5. Click View.
Related Information
