Self Service Configuration Profiles for Mobile Devices
You can make any iOS configuration profile available in Jamf Self Service for iOS, but it is up to you to determine which profiles are appropriate.
When you make a configuration profile available in Self Service, you can specify which mobile devices display it in Self Service and which users can access it (called “scope”).
You can also customize how Self Service configuration profiles are displayed to users by doing the following:
  • Entering a description
  • Uploading an icon
  • Featuring the configuration profile
  • Displaying the configuration profile in one or more categories
Creating a Self Service Configuration Profile
  1. Log in to Jamf Pro.
  3. Click Configuration Profiles.
  4. Do one of the following:
    • To use Jamf Pro to manually create a new configuration profile, click New images/download/thumbnails/18777695/Icon_New_Button.png .
    • To upload a configuration profile (.mobileconfig) that was created using Apple’s Profile Manager, click Upload.
    For more information about configuration profiles, see Mobile Device Configuration Profiles.
  5. On the General pane, select “Make Available in Self Service” from the Distribution Method pop-up menu and configure the rest of the settings as needed. You can customize the text displayed in the description for the profile in Self Service by using Markdown in the Description field.
    For information about Markdown, see the following Knowledge Base article:
    Using Markdown to Format Text
  6. Use the rest of the payloads to configure the settings you want to apply.
  7. Click the Scope tab and configure the scope of the configuration profile.
    For more information, see Scope.
  8. Click the Self Service tab and configure how the configuration profile is displayed in Self Service using the settings on the pane.
  9. Click Save.
The configuration profile is displayed in Self Service on mobile devices in the scope the next time they check in with Jamf Pro and meet the criteria in the General payload.
Related Information
Installing Configuration Profiles from Self Service
Learn how users install the configuration profiles available in Self Service.
