Jamf Pro User Accounts and Groups
Jamf Pro is a multi-user application. Jamf Pro user accounts and groups allow you to grant different privileges and levels of access to each user.
When configuring a Jamf Pro user account or group, you can grant access to the full Jamf Pro or to a specific site. You can grant privileges by choosing one of the following privilege sets:
Administrator—Grants all privileges.
Auditor—Grants all read privileges.
Enrollment Only—Grants all privileges required to enroll computers and mobile devices.
Custom—Requires you to grant privileges manually.
If there are multiple users that should have the same access level and privileges, you can create a group with the desired access level and privileges and add accounts to it. Members of a group inherit the access level and privileges from the group. Adding an account to multiple groups allows you to grant a user access to multiple sites.
There are two ways to create Jamf Pro user accounts and groups: you can create standard accounts or groups, or you can add them from an LDAP directory service.
Important: It is recommended that you have at least one account that is not from an LDAP directory service in case the connection between the Jamf Pro server and the LDAP server is interrupted.
The Jamf Pro User Accounts and Groups settings also allow you to do the following:
Configure account preferences for each Jamf Pro user account.
Configure the password settings in the Password Policy for all standard Jamf Pro user accounts.
Unlock a Jamf Pro user account that is locked.
Requirements
To add accounts or groups from an LDAP directory service, you need an LDAP server set up in Jamf Pro. (For more information, see Integrating with LDAP Directory Services.)
Creating a Jamf Pro User Group
Log in to Jamf Pro.
In the top-right corner of the page, click Settings
Click System Settings.
Click Jamf Pro User Accounts & Groups
Click New
Do one of the following:
To create a standard Jamf Pro user group, select Create Standard Group and click Next.
To add a Jamf Pro user group from an LDAP directory service, select Add LDAP Group and click Next. Then follow the onscreen instructions to search for and add the group.
Use the Group pane to configure basic settings for the group.
If you chose “Custom” from the Privilege Set pop-up menu, click the Privileges tab and select the checkbox for each privilege that you want to grant the group.
Click Save.
Creating a Jamf Pro User Account
Log in to Jamf Pro.
Click New
To create a standard Jamf Pro user account, select Create Standard Account and click Next.
To add a Jamf Pro user account from an LDAP directory service, select Add LDAP Account and click Next. Then follow the onscreen instructions to search for and add the account.
On the Account pane, enter information about the account as needed.
Choose an access level from the Access Level pop-up menu:
To grant full access to Jamf Pro, choose “Full Access”.
To grant access to a site, choose “Site Access”.
Note: The “Site Access” option is only displayed if there are sites in Jamf Pro. For more information on adding sites to Jamf Pro, see Sites. -
To add the account to a standard group, choose “Group Access”.
Note: The “Group Access” option is only displayed if there are standard groups in Jamf Pro. For more information on creating groups, see Creating a Jamf Pro User Group.
If you granted the account full access or site access, choose a privilege set from the Privilege Set pop-up menu. Then, if you chose “Custom”, click the Privileges tab and select the checkbox for each privilege that you want to grant the account.
If you added the account to a group, click the Group Membership tab and select the group(s) you want to add the account to.
Click Save.
Configuring Account Preferences
You can configure Language & Region and Search preferences for each Jamf Pro user account. Language & Region preferences allow you to configure settings such as date format and time zone. Search preferences allow you to configure settings for computer, mobile device, and user searches.
Log in to Jamf Pro.
At the top of the page, click the account settings
icon and then click Account Preferences.
Click the Language & Region tab and use the pop-up menus to configure language and region preferences.
Click the Search Preferences tab and use the pop-up menus to configure search preferences.
Note: The default search preference is “Exact Match”. For most items, the option can be changed to either “Starts with” or “Contains”. -
Click Save.
Configuring the Password Policy
The Password Policy in Jamf Pro allows you to configure the password settings. The Password Policy applies to all standard Jamf Pro user accounts. You can configure the following password settings:
Number of login attempts allowed before a Jamf Pro user is locked out of the account
Password length and age
Password reuse limitations
Password complexity
Settings to allow a user to unlock their own account
Note: The settings configured in the Password Policy do not apply to Jamf Pro user accounts added from an LDAP directory service.
Log in to Jamf Pro.
Click Password Policy.
Click Edit.
Use the settings on the pane to specify the password settings.
Click Save.
The settings are applied immediately.
Unlocking a Jamf Pro User Account
A Jamf Pro user could be locked out of their account if they exceed the specified number of allowed login attempts. If the Password Policy is configured to allow the user to unlock their account, the user can reset their password to unlock their account. In this case, an email is immediately sent to the email address associated with the account in Jamf Pro allowing the user to unlock their account by resetting their password. For an email to be sent, an SMTP server must be set up in Jamf Pro. (For more information, see Integrating with an SMTP Server.)
In addition, a Jamf Pro user account that is locked can be manually unlocked from Jamf Pro by another Jamf Pro user with the Administrator privilege set.
The access status of the account is displayed as “Disabled” in Jamf Pro until the account is unlocked.
Log in to Jamf Pro.
A list of Jamf Pro user accounts and groups is displayed. -
Click the Jamf Pro user account that has an access status of “Disabled”, which means the account is locked.
Click Edit.
Choose “Enabled” from the Access Status pop-up menu to unlock the account.
Click Save.
The Jamf Pro user account is unlocked immediately.
Related Information
Sites
Learn about sites and how to add them to Jamf Pro.
