Mobile Device Management Capabilities
Jamf Pro can be used to enroll and manage institutionally owned iOS and tvOS devices, and personally owned iOS devices. The management capabilities available for a particular device vary depending on the device ownership type, device type, and OS version.
This section includes information for OS versions that meet the minimum system requirements for managed mobile devices in Jamf Pro. For information on these requirements, see Jamf Pro System Requirements.
Note: This section provides an overview of mobile device management capabilities by OS version and does not account for additional feature-specific requirements. For information on feature-specific requirements, see the documentation for that feature.
Management Capabilities for Mobile Devices
The following table provides an overview of the management capabilities available with Jamf Pro for iPad, iPhone, and iPod touch devices by iOS version:
iOS Version
9
10
11
12
Personally Owned iOS Device Support
Enrollment
Via user-initiated
enrollment
images/download/thumbnails/19534239/checkmark.png
Via an enrollment
profile and Apple
Configurator
Via an enrollment
profile and Apple
Configurator 2
Via Apple's DEP using a PreStage enrollment
Via Apple's DEP using a PreStage enrollment and Apple Configurator 2
Via Apple
Configurator 2
using an enrollment URL
Inventory
Submit inventory to
Jamf Pro
images/download/thumbnails/19534239/checkmark0.png 1
Extension attributes
Simple searches
Advanced searches
Mobile device reports
Mass actions
images/download/thumbnails/19534239/checkmark0.png 2
Device Groups
Static groups
Smart groups
Configuration
iOS configuration profiles
Personal device profiles
Remote Commands3
Update inventory
Lock device
Clear passcode
Update passcode lock grace period
Clear restrictions
Wipe device
Unmanage device
Wipe institutional data
Send blank push
Set wallpaper
Enable/disable voice or data roaming
Update iOS version via mass action
Log out user (Shared iPad only)
Enable/disable Lost Mode
Update location
Enable/disable diagnostic and usage reporting (Shared iPad only)
Enable/disable app analytics (Shared iPad only)
Shut down device (Shared iPad only)
Restart device
Enable/disable Bluetooth
Set Activation Lock
Jamf Self Service for iOS
Jamf Self Service app
iBeacon region monitoring
Self Service web clip
App Distribution
Managed apps
VPP-managed distribution for mobile devices
VPP-managed distribution for users
In-house apps
images/download/thumbnails/19534239/checkmark0.png 4
App Store apps
Book Distribution
Managed books
Install ePub file
Install iBooks file (iPad only)
Install PDF
Notes:
1. A limited subset of inventory information is collected for personal devices. For more information, see Viewing and Editing Inventory Information for a Mobile Device.
2. Lock Device and Update Inventory are the only remote commands that can be sent via mass action to personally owned devices.
3. This table does not account for additional requirements like supervision or enrollment using a PreStage enrollment. For information on specific device requirements for each command, see Remote Commands for Mobile Devices.
4. Only managed apps can be distributed to personal devices.
Management Capabilities for tvOS Devices
The following table provides an overview of the management capabilities available with Jamf Pro for institutionally owned Apple TV devices by tvOS version:
tvOS Version
11
12
Enrollment
Via an enrollment
profile and Apple
Configurator
Via an enrollment
profile and Apple
Configurator 2
Inventory
Submit inventory to
Jamf Pro
Device Groups
Static groups
Smart groups
Configuration
Mobile device configuration profiles
Remote Commands
Update inventory
Unmanage device
Wipe device
Send blank push
Restart device
App Distribution
In-house apps
App Store apps
