Computer Management Capabilities
Jamf Pro can be used to enroll and manage Mac computers. The management capabilities available for computers vary depending on the macOS version.
This section includes information for OS versions that meet the minimum system requirements for managed computers in Jamf Pro. For information on these requirements, see Jamf Pro System Requirements.
Note: This section provides an overview of computer management capabilities by OS version and does not account for additional feature-specific requirements. For information on feature-specific requirements, see the documentation for that feature.
Management Capabilities for Computers
The following table provides an overview of the management capabilities available with Jamf Pro for computers by macOS version:
macOS Version
10.11
10.12
10.13
10.14
Enrollment
Via user-initiated enrollment
images/download/thumbnails/20219268/checkmark.png
Via QuickAdd package created using Recon
Via the network scanner
Via remote enrollment using Recon
Via local enrollment using Recon
Via Apple's DEP using a PreStage enrollment
Via imaging using Jamf Imaging
Inventory
Submit inventory to Jamf Pro
Extension attributes
Simple searches
Advanced searches
Computer reports
Mass actions
Computer Groups
Static groups
Smart groups
Self Service
Install Self Service
Display badges for available software updates on the Dock icon
Software Distribution
VPP-managed distribution for computers
VPP-managed distribution for users
Mac App Store apps
Install packages
Remote Control
Screen sharing
Configuration
macOS configuration profiles
Run scripts
Administer printers
Administer Dock items
Administer local accounts
Administer the management account
Bind to directory services
Deploy disk encryption configuration
Issue a new FileVault 2 recovery key
Administer open Firmware or EFI passwords
Perform an authenticated restart on FileVault 2-enabled computers
Remote Commands for Computers
Lock computer
Remove MDM profile
Wipe computer
Send blank push
Download/Download and Install Updates1
Unlock User1
Remove User 1
Enable/Disable Bluetooth
Usage Management
View Application Usage logs
View Computer Usage logs
Restrict software
Book Distribution
Install ePub file
Install iBooks file
Install PDF
Notes:
1. Requires enrollment via a PreStage enrollment.
