Change Management
Change Management allows you to track the changes that happen in Jamf Pro, such as the creation of a Jamf Pro user account. The Change Management settings in Jamf Pro allow you to log those changes to a log file (JAMFChangeManagement.log) on the Jamf Pro host server and log the changes to a syslog server.
The Change Management logs can also be viewed in Jamf Pro. The information displayed includes:
  • Date/time the change took place
  • Username of the administrator who made the change
  • Object type (such as a Jamf Pro user account)
  • Object name (such as the username of a Jamf Pro user account)
  • Action (such as “Created”)
  • Details about the change
In addition, you can view the changes to a specific object in that object’s history. For more information, see Viewing the History of a Jamf Pro Object.
Requirements
To log changes to a log file, the account used to run Tomcat must have write permissions for the directory where the JAMFChangeManagement.log file is located.
Configuring the Change Management Settings
  1. Log in to Jamf Pro.
  2. In the top-right corner of the page, click Settings images/download/thumbnails/19535313/Icon_Settings_Hover.png .
  3. Click System Settings.
  4. Click Change Management images/download/thumbnails/19535313/Change_Management.png .
  5. Click Edit.
  6. Configure the settings on the pane.
  7. Click Save.
Viewing Change Management Logs in Jamf Pro
  5. Click Logs.
    The Change Management logs are displayed on the pane.
  6. Do one of the following:
    • To view the object associated with a change, click the object in the Object Name column.
    • To view details about the change, click Details in the Details column.
