Startup Script
The Startup Script settings in Jamf Pro allow you to create a startup script on computers and use it to perform the following actions at startup:
  • Log Computer Usage information (date/time of startup).
  • Check for policies triggered at startup.
  • Ensure SSH (Remote Login) is enabled on computers.
Configuring the Startup Script
  1. Log in to Jamf Pro.
  2. In the top-right corner of the page, click Settings images/download/thumbnails/16441076/Icon_Settings_Hover.png .
  3. Click Computer Management.
  4. In the “Computer Management–Management Framework” section, click Check-In images/download/thumbnails/16441076/Check-In.png .
  5. Click the Startup Script tab.
  6. Click Edit.
  7. Configure the settings on the pane.
  8. Click Save.
Related Information
Components Installed on Managed Computers
Find out where the startup script is stored on computers.
