Jamf Self Service for macOS Branding Settings
The Self Service Branding settings allow you to configure how Jamf Self Service for macOS is displayed by replacing the default icon, header image, and application name with custom branded elements to present end users with a familiar look and feel.
You can customize how Self Service displays to your end users by configuring the following settings:
  • Branding Icon—The branding icon displays on the Self Service Login page, in the branding header in Self Service, and as the Self Service icon in the Finder and the Dock. You can customize the branding icon by replacing the default Self Service logo with your organization's logo or another icon of your choice. It is recommended that you use a file with the GIF or PNG format that is 512x512 pixels.
  • Branding Header—The branding header displays across the top of Self Service. You can customize the branding header image by replacing the default image with an image of your choosing. It is recommended that you use a file with the GIF or PNG format that is 1500x500 pixels.
  • Branding Name—The branding name displays on the Self Service Login page and in the branding header in Self Service. By default, "Self Service" is displayed as the branding name. You can customize the branding name by selecting the Customize branding name option and modifying the following text fields:
    • The Main Header field is automatically populated with the organization name you entered during the initial setup of your Jamf Pro instance.
    • The Secondary Header field is automatically populated with "Self Service".
Note: You can also customize the application name that displays in the Finder and the Dock by modifying the "Self Service" name in the Installation Location text field on the Configuration tab in the Self Service settings. For example:
/Applications/My Company's Self Service.app
The screen shot below shows how the default branding settings look when viewed from the "Featured" category in Self Service.
images/download/attachments/17118000/Self_Service_Featured_Category.png
Configuring the Branding Settings for Self Service
  1. Log in to Jamf Pro.
  2. In the top-right corner of the page, click Settings images/download/thumbnails/17118000/Icon_Settings_Hover.png .
  3. Click Computer Management.
  4. In the "Computer Management–Management Framework” section, click Self Service images/download/thumbnails/17118000/Icon_Self_Service_for_macOS.png .
  5. Click Edit.
  6. Click the Branding tab.
  7. Configure the settings on the pane.
    Once a change is made, it automatically appears in the Branding Preview field at the top of the page.
  8. Click Save.
    The settings are applied the next time computers check in with Jamf Pro.
You are now ready to start making items available in Self Service. For instructions, see Making Items Available to Users in Jamf Self Service for macOS.
Related Information
For related information, see the following Jamf Knowledge Base video:
Customizing Self Service for macOS using Jamf Pro
