Autorun Imaging Settings
The Autorun imaging settings in Jamf Pro allow you to configure the following settings for Autorun imaging:
  • The delay before the imaging process starts automatically
    This only applies if a computer’s Autorun data is configured to start the imaging process automatically. During the delay, a pane is displayed that allows you to cancel the imaging process.
  • The amount of space to leave available when caching files
  • The attribute to use for comparing cached files to files on a distribution point
    This ensures that the most up-to-date files are cached on the computer.
Configuring the Autorun Imaging Settings
  1. Log in to Jamf Pro.
  2. In the top-right corner of the page, click Settings images/download/thumbnails/16442012/Icon_Settings_Hover.png .
  3. Click Computer Management.
  4. In the ”Computer Management–Management Framework” section, click Autorun Imaging images/download/thumbnails/16442012/Icon_Autorun_Imaging.png .
  5. Click Edit.
  6. Configure the settings on the pane.
  7. Click Save.
Related Information
Autorun Imaging
Find out how to image computers using Autorun imaging.
