SSL Certificate
Jamf Pro requires a valid SSL certificate to ensure that computers and mobile devices communicate with the Jamf Pro server and not an imposter server.
The Apache Tomcat settings in Jamf Pro allow you to create an SSL certificate from the CA that is built into Jamf Pro. You can also upload the certificate keystore for an SSL certificate that was obtained from an internal certificate authority (CA) or a trusted third-party vendor.
Note: If your environment is hosted in Jamf Cloud, the Apache Tomcat settings are managed by Jamf Cloud and are not accessible.
Requirements
To create or upload an SSL certificate, Jamf Pro must be installed as the “ROOT” web app, and the user running the Tomcat process must have read/write access to Tomcat’s server.xml file.
Creating or Uploading an SSL Certificate
  1. Log in to Jamf Pro.
  2. In the top-right corner of the page, click Settings images/download/thumbnails/16442037/Icon_Settings_Hover.png .
  3. Click System Settings.
  4. Click Apache Tomcat Settings images/download/thumbnails/16442037/Apache_Tomcat_Settings.png .
  5. Click Edit.
  6. Select Change the SSL certificate used for HTTPS and click Next.
  7. Follow the onscreen instructions to upload or create an SSL certificate.
  8. Restart Tomcat for the changes to take effect.
    For instructions on how to restart Tomcat, see the following Knowledge Base article:
    Starting and Stopping Tomcat
Related Information
Using OpenSSL to Create a Certificate Keystore for Tomcat
Find out how to use OpenSSL to create a certificate keystore that you can upload to Jamf Pro.
