Mobile Device Reports
The data displayed in smart or static group membership lists or mobile device search results can be exported from Jamf Pro to the following file formats:
  • Comma-separated values file (.csv)
  • Tab delimited text file (.txt)
  • XML file
You can change the way the data is organized by basing the export on any of the following inventory items:
  • Mobile devices
  • Device groups
  • Apps
  • Configuration profiles
  • Certificates
The data is displayed in alphanumeric order by the selected inventory item.
Creating Mobile Device Reports
  1. Log in to Jamf Pro.
  3. Do one of the following:
  4. At the bottom of the list, click Export.
  5. Follow the onscreen instructions to export the data.
The report downloads immediately.
