Maintenance Pages
The Maintenance Pages setting allows you to create a custom maintenance page for each language used in your environment.
The maintenance page is displayed to users when Jamf Pro is starting up or being upgraded under the following conditions:
  • When using the Self Service web clip
  • During enrollment
A maintenance page configuration is preconfigured in Jamf Pro for each of the following languages: English, French, and German. When a computer or mobile device has a preferred language set on it, it displays the maintenance page configuration that corresponds with that language. The English version of the maintenance page is displayed if the computer or mobile device does not have a preferred language set on it.
In addition to the language, the message and the graphic displayed on the maintenance page can be customized. The preconfigured maintenance page message is “We’ll be back.” You can use Markdown to format the maintenance page message and image.
For information about Markdown, see the following Knowledge Base article:
Using Markdown to Format Text
Creating a Maintenance Page Configuration
  1. Log in to Jamf Pro.
  2. In the top-right corner of the page, click Settings images/download/thumbnails/16442050/Icon_Settings_Hover.png .
  3. Click System Settings.
  4. Click Maintenance Pages images/download/thumbnails/16442050/MaintenancePages.png .
  5. Click New images/download/thumbnails/17105124/Icon_New_Button.png and then use the Language pop-up menu to specify the language that will be contained within the message. Computers and mobile devices with a preferred language that matches the specified language will display this version of the maintenance page.
  6. Use the Maintenance Page Message field to customize the message displayed during the Jamf Pro maintenance process.
  7. Click Save.
  8. Repeat this process as needed for other languages.
