Jamf Push Proxy
The Jamf Push Proxy enables communication between the Jamf Pro server and devices with Jamf Self Service installed, and between the Jamf Pro server and personally owned Android devices. Push notifications trigger the following types of communication between the Jamf Pro server and devices in your environment:
  • Sending Notification Center notifications to computers and mobile devices with Self Service installed
  • Requesting management check-ins from personally owned Android devices
Jamf Pro requires a valid proxy server token to authenticate to the Jamf Push Proxy. An assistant in Jamf Pro guides you through the process to request a new proxy server token from the Jamf Authorization Server and upload it to Jamf Pro.
The following diagram illustrates the communication between the Jamf Push Proxy and the Apple Push Notification service (APNs), Google Cloud Messaging (GCM), Jamf Pro, and devices in your environment:
images/download/attachments/16442107/Jamf_Push_Proxy_Communication.png
Requirements
To request or renew a proxy server token, you need a valid Jamf Nation account.
To create a Jamf Nation account, go to:
https://www.jamf.com/jamf-nation/users/new
Requesting and Uploading a Proxy Server Token
  1. Log in to Jamf Pro.
  2. In the top-right corner of the page, click Settings images/download/thumbnails/16442107/Icon_Settings_Hover.png .
  3. Click Global Management.
  4. Click Push Certificates images/download/thumbnails/16442107/Push_Certificates.png .
  5. Click New images/download/thumbnails/16442107/Icon_New_Button.png .
  6. Select Get proxy server token from Jamf Authorization Server.
  7. Follow the onscreen instructions to get the proxy server token and upload it to Jamf Pro.
Renewing the Proxy Server Token
Note: The proxy server token will be renewed automatically, however, the following steps can be used for troubleshooting purposes.
  5. Click the push proxy and then click Renew.
