Deleting a Computer from Jamf Pro
You can remove a computer from your inventory by deleting it from Jamf Pro.
The files and folders installed during enrollment are not removed from the computer when it is deleted from Jamf Pro. For instructions on how to remove these components, see the Removing Jamf Components from Computers Knowledge Base article.
  1. Log in to Jamf Pro.
  3. Click Search Inventory.
  4. Perform a simple or advanced computer search.
    For more information, see Simple Computer Searches or Advanced Computer Searches .
  5. Click the computer you want to delete.
    If you performed a simple search for an item other than computers, such as computer applications, you must click Expand images/download/thumbnails/16441284/Icon_Expand.png next to an item name to view the computers related to that item.
  6. Click Delete, and then click Delete again to confirm.
Related Information
Mass Deleting Computers
Find out how to mass delete computers from Jamf Pro.
